Hi guys,
Having a bit of a shocker today with the revit link;
When I change the reinforcing bar database to AS3600, the link will not update reinforcement into the footings in Revit. It was working for ACI bars.
So if I use AS3600 bars, it throws an exception (i've attached a txt file with the exception text). Also attached the Robot file. Using Robot and Revit 2013.
Cheers,
Tony
No, not implemented yet.
In the original post i was referring to some RC design I did with various other codes using Australian rebar, then importing into Revit.
Have you done any? if so, how?
Tony
Rafal,
Thanks, but I don't 100% agree.
It seems that we have been given required reinforcement check for slabs and beams only? Not columns.
And no check for provided reinforcement, only required.
It's better then nothing I guess, but still not perfect
Tony
We are downloading now, I'll throw my 2 cents work in when I've had a play.
Yes, only theoretical reinforcement
If you want more : http://forums.autodesk.com/t5/Robot-Structural-Analysis/idb-p/93
heheh did that 10 months ago 🙂
http://forums.autodesk.com/t5/Robot-Structural-Analysis/Concrete-design-to-AS3600/idi-p/3747078
