RC DESIGN - BUCKLING - Effective Length Factor K (When concrete Frame in ROBOT)
5 REPLIES 5
athurD
1577 Views, 5 Replies
Hi. Suport
Please help me. I want find Effective Length Factor K in robot. THanks
Tags (2)
5 REPLIES 5
Artur.Kosakowski
in reply to: athurD
See the attached picture.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
athurD
in reply to: Artur.Kosakowski
Thansk. Artur.Kosakowski
Picture is caculation cloum
 So when caculation Beam, Wall??
Artur.Kosakowski
in reply to: athurD
The effect of buckling is disregarded for RC Beams design. The RC Wall module is currently not available for SNIP codes
Artur Kosakowski
athurD
So when caculation wall code not SNIP. Yes i kown
But where edit Effective Length Factor K when use code ACI ????
Thansk
Artur.Kosakowski
in reply to: athurD
Not available in Robot. I have limited knowledge of ACI code  - does it address this issue directly and if it does which paragraph of the code is it?
Artur Kosakowski
