why is manual combinations off when i select column to design .. how i generate it ?
Solved by Artur.Kosakowski. Go to Solution.
You need to define manual combinations in the model first (Loads > manual combinations). Otherwise combinations are generated automatically by the RC Design module based on the simple cases (this is as far as I can see your case).
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
I made the combinations .. when i select beam the manual combinations appear .. but when i do it with column it's not work
file is here
http://www.filemail.com/d/bnmnclhvzanditk
B.R
I don't have any issue with using the manual combinations fro RC Column design in your file.
Try to install Robot 2014 SP3 (replaced by) SP5.
