Hi
Just a quick question, what is the purpose of boxes shown below?
Thankts
Regards Peder
Solved by Artur.Kosakowski. Go to Solution.
Run for ULS and SLS automatic code combinations.
I have ULS, ULS+ and ULS- which i choose. However, when I activate the box this field is grayed out and only ULS is choosen. Could you please elaborate the difference here if there is any?
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Code-combinations/m-p/3274975
