I'm trying to understand the RC Design Module for Beams and in the code parameters menu i see that is possible to verify the deflections but this option in unavaliable. Is there a reason for that? Other question: Does the software calculate the long term deflection? or it only verifies the elastic deflection?
Thanks in advance!
Filipe
The option should be available as shown below:
Yes, it does.
http://docs.autodesk.com/RSA/2013/ENU/filesROBOT/GUID-F16433AA-1620-4CDE-80CB-7F138726EE53.htm
