how can we scale automaticly final drawings of a list of beams to fit to the paper format ( A4 by default ) ?
Solved by faisal.aaouatif. Go to Solution.
By default the scale is automatically set to fit the selected paper size. The settings are available in the way shown on the scale picture.
In case you want to change the paper size try to follow these steps:
1. Create and calculate all beams
2. Generate reinforcement with the default paper size
3. In case you want to change the paper size for the generated drawings
a) make sure you have Drawings tab in the Inspector active
b) switch off arrange drawings automatically
c) change page setup
See A4 and A3 that illustrate these steps.
thank you very much
Hi Artur,
Ive been trying to make some drawings of a Double pier foundation, however the drawings are scaled on 1:50, when i try to change it, the scale factor is unclickable, like in this picture.
I tried to look for the help, and it was not very helpfull.. it says to go to the parameters.. printouts.. scales.. i cant really find this .. howver the scaling option is on the help menu.. http://docs.autodesk.com/RSA/2013/ENU/index.html?url=filesROBOT/GUID-44B65DE2-0708-4E32-B09A-69C8FFD..., how can i reach it??
Why don't you switch from auto to user in the scale modes line?
Of course i tried but is the same, cant change the Scale even with user scale...
I read in the Help, that it is because the drawing is saved and cannot be scaled.. as it says in the botton part of the image, there is suppose to be a Scaling section in Preferences, where u can select different scales in paper.. there is even an image of the windows.. the problem is i cant find this "Scales Tab" in properties..
Regards.
Open the Drawing Parameters dialog
im sorry Artur, but that is just what im asking, i just cant find that dialog box in "Preferences", is it needed to be in the printouts sections??
