Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
RC BEAM DESIGN - DEFINING SUPPORTS - coupled beam problem
1 REPLY 1
ibrahim_sabry
670 Views, 1 Reply
hi there
i made tow walls and i joined them by a beam and when i select the beam to be designed robot complains that there must be at least tow supports to the beam isn't the wall considered as a support ?
IBS
1 REPLY 1
You need to mark what should be considered as a support in case it is not set as such by default.
Artur Kosakowski
