Discussion Groups
Robot Structural Analysis
Valued Contributor
RRufino
Purlin Design - Rotational Stiffness
406 Views, 5 Replies
12-27-2013 09:00 AM
I'm writing this post while testing cold formed purlin design taking advantage of steel sheeting stiffness (Eurocode 3 - EN1993-1-3).
This is an eurocode and robot doubt, taking a look on a random purlin detailed result there is CDA: rotational stiffness of the connection between the sheeting and the purlin. Eurocode expression is: CD,A=C100.kbA.kt.kbR.kA.kbT, where for gravity loads kA has 4 expressions depending on sheeting position and thickness, but all depending from "A: load introduced from sheeting to beam". How is robot calculating this value A?
Thanks in advance,
Best Regards,
RR
Please use plain text.
Product Support
Artur.Kosakowski
Re: Purlin Design - Rotational Stiffness
12-30-2013 06:02 AM in reply to: RRufino
A is assumed as the maximal value allowed by the  the point 10.1.5.2.(5)  = 12 kN/m
Artur Kosakowski
Valued Contributor
RRufino
12-30-2013 07:15 AM in reply to: RRufino
Thanks Artur but in fact, as far as i could understand, using the highest boundary of "A" lead us to optimistic (non-conservative) approach. This is not we expect from design software (if it was a conservative approach, i was ok with it).
If possible please take a look to this issue.
RR
Product Support
Artur.Kosakowski
12-30-2013 07:36 AM in reply to: RRufino
I have added the request for the manual definition of A value to the wish list.
Artur Kosakowski
Valued Contributor
RRufino
01-03-2014 03:05 AM in reply to: Artur.Kosakowski
Thanks Artur, nice idea.
You can also consider to give a chance to users choose that CDA is determinated by 10.1.5.2 (7), in my opinion this is the way commonly used by structural designers.
Have a nice 2014 :smileywink:
Product Support
Artur.Kosakowski
01-07-2014 07:38 AM in reply to: RRufino
As there are 3 ways of calculating CD,A and two for CD,C I have created the request for the possibility of manual definition of CD (10.1.5.2(1))
Artur Kosakowski
