Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Project Octopus seamlessly access Robot data and results with Excel
44 REPLIES 44
Message 1 of 45
Romanich
5582 Views, 44 Replies
The newest addin from Autodesk Labs  - Project Octopus that allows designers and engineers using Autodesk Robot Structural Analysis to seamlessly access data and results with Microsoft Office Excel. To know more about it please use this link.
For the first look this is the Excel_Formulas.xlsm from the 2014 SDK.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Tags (2)
44 REPLIES 44
Message 41 of 45
Romanich
in reply to: Romanich
Octopus has got a new update! Many thanks to DEV team!
1) Panel Data
The formula returns values of several properties assigned to panels in RSA. You can use this formula to read the geometry, area, material, and calculation model of selected panels.
2) Panel Thickness
The formula provides a complete set of values which define the thickness of selected panel in RSA. You can use this formula to analyze the type of the thickness and read values of properties which are specific to given thickness type which are assigned to given panel.
3) Extreme Results for Plates and Shells
New result formulas provide information about minimum and maximum values of forces, displacements, and stresses for surface elements. You can obtain global extremes as well as define specific criteria to be considered when searching for an extreme value only within a selected part of the structure. As a result you retrieve the extreme value of selected result and the information describing where the extreme occurs.
Roman Zhelezniak
Message 42 of 45
Romanich
Robot 2016 has a new application - Results Connect (ex Project Octopus). Results Connect is automatically installed with Robot by default.
Roman Zhelezniak
Message 43 of 45
pipiyedu
I don´t have RSA 2016. How can I use this features with RSA 2015?
Greetings.
Message 44 of 45
scott.sheppard
in reply to: pipiyedu
This feature is available for those who can take advantage of the upgrade to RSA 2016. I recognize that this is not possible for all customers due to a variety of factors.
Sent from my iPhone
Scott Sheppard
Program Manager
Autodesk Labs
Autodesk, Inc.
Message 45 of 45
Hi Stefano,
why do I always get this result when I am using the excil file you shared? (see the attached photo pls)
