I'm testing the Analisys Professional 2014 Autodesk Robot, and I have encountered the problem of the design of the columns, and I need to make this design according to the manual combinations Annex in this image:
But I get the following window, where this option is disabled, and do not know what the reason, and also gives me the opportunity to see the simple cases which I will include in the design.
I appreciate your help in solving this problem; Excuse my English.
Solved by Artur.Kosakowski. Go to Solution.
Mr Rafael, I send my model as an attachment, also images of my configurations options.
This model is smaller than the one in my post, but has the same problem. I tried with the combination codes: LFRD ASCE 7-10, ACI 318, and all the same thing happens.
Thank you for your help.
This is additional information on the model sent in the previous post, here I will show graphically the design process of the RC beams, where I have no problem, in contrast to the RC column layout, where you disable "Combinations Manuals ".
LIST OF MANUAL COMBINATIONS
DESING of the RC BEAMS
Simple Cases.
Manual Combinations
In this if it appears the list of "Combinations Manuals"
DESING of the RC COLUMNS
This option disables the "Combinations Manuals"
Thanks for reporting.
We will correctct it asap.
(it works fine in 2013).
