I'm experiencing a problem when i try to apply a perpendicular load to A PART of a cladding. The program is generating a load according to global Z axis and i want to consider the cladding Z axis.
Please see pictures below:
1. Applying the Load:
2 - Final Result
The result should be : Load perpendicular to panel and with opposite sign!
I tryed with planar load 3p on contour and the result is the same.
Thanks in advance!
Filipe Ribeiro
Solved by Artur.Kosakowski. Go to Solution.
Please check the attached picture. Mind to generate model first.
Hi Artur,
Thanks for the quick response, but i think you miss understood me.
This is what i want:
(this picture is edited in paint. I cant make the software generate a load like this)
And this is what i get (using uniform planar load on contour and with Planar load 3p on contour):
The loaded element its a cladding, not a bar! and i want to apply a load in part of it.
Thanks!
FR
EDIT: I'm reaching the conclusion that the calculations are right but the graphical representation is wrong. Is it true?
The display of the load definition is actually as you said but this is not the load as finally applied to the bars that 'support' the cladding. During the model generation this load is 'replaced' with load applied to the bars and which can be visible in the way I indicated on the picture (red frames). Such generated bar loads should no longer be vertical but inclined according to the local Z axis of the cladding. This is the reason the loads applied to bars are generated as vertical and horizontal ones (the equivalent loads will be parallel the local Z of the cladding).
Just a conclusion note:
I think the graphical representation should be perpendicular to cladding, otherwise it could lead to modeling errors.
Thanks!
This load is a bit more versatile and therefore not that easy to be shown without switching to the 'model generated' one
