I have generated a few basic loads and I wanted to generate automatic combinations of loads. But everytime I try to do it, I see a window that tells "Warning! The regulations have change. Do you want to remove the definitions of code combinations and define new using the new regulations? In this case, the default parameters will be adopted. [translated from Polish]".
When I accept it, it pops-up a standard window of combinations generation and when I hit generate, nothing happens. What might be a problem?
In attachment, there is my file.
Solved by StefanoPasquini6790. Go to Solution.
"you have to go in the next label and define new rules of combination for each group of load, erasing all the existing ones" Could you, please share some print-screens as it is unclear for me how to do that. Thanks as lot 🙂
Thanks Artur for translating in immages my unclear words!! Your contribution is always precious for us.
Thanks again for your commitment.
