I can not understand why in the calculation model which is attached panels 351 353 354 and 363 do not share the load.
The model is imported from Revit, but the other panels are correct.
Solved by Artur.Kosakowski. Go to Solution.
The reason is setting the user defined tolerance for model generation as 0. Any particular reason for that ?
Anyway I have asked the development team to disable such possibility in the future.
The solution is e.g. to change to Automatic instead.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
