Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Problem with SpreadSheet Calculator 2013
2 REPLIES 2
TraitCarré
360 Views, 2 Replies
please find enclosed a Robot file plus 2 spreadsheets. We're trying to calculate the joint between bars 2 and 4.
1st problem :
We can't load the values from Robot.
2nd problem :
When we enter the values by hand, the spreadsheet bugs when changing the angle (alpha), and stops calculating.
The file called 33SCHM_TIMB_EC5_009_BUG.xls was created after this bug.
The file called 33SCHM_TIMB_EC5_009.xls was created before it.
Thanks for your help.
Rgds
Benoît
2 REPLIES 2
We will investigate the import issue you reported (mind that it is required you divide bar 2 into two parts at the location of node 5). For the angle try to use the workaround shown on the attached movie.
Artur Kosakowski
Ok for the angle.
We've already tried to divide the bar 2, without success.
benoît
