Discussion Groups
Robot Structural Analysis
Valued Contributor
TraitCarré
Problem with SpreadSheet Calculator 2013
260 Views, 2 Replies
11-15-2012 09:24 PM
please find enclosed a Robot file plus 2 spreadsheets. We're trying to calculate the joint between bars 2 and 4.
1st problem :
We can't load the values from Robot.
2nd problem :
When we enter the values by hand, the spreadsheet bugs when changing the angle (alpha), and stops calculating.
The file called 33SCHM_TIMB_EC5_009_BUG.xls was created after this bug.
The file called 33SCHM_TIMB_EC5_009.xls was created before it.
Thanks for your help.
Rgds
Benoît
Please use plain text.
Product Support
Artur.Kosakowski
Re: Problem with SpreadSheet Calculator 2013
11-16-2012 03:12 AM in reply to: TraitCarré
We will investigate the import issue you reported (mind that it is required you divide bar 2 into two parts at the location of node 5). For the angle try to use the workaround shown on the attached movie.
Artur Kosakowski
Valued Contributor
TraitCarré
11-16-2012 03:45 AM in reply to: Artur.Kosakowski
Ok for the angle.
We've already tried to divide the bar 2, without success.
benoît
