Hi again,
This problem have common roots with this and this, but in this case problem very serious.
For example, I have several panels, selected them and copied list "2до6" to the clipboard. After then paste this data for Load table (for example) and obtain this:
After pressing Enter, only panels 1, 2 and 6 will be loaded. Please, watch the video.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
Solved by Pawel.Pulak. Go to Solution.
Hi Roman,
please try to change active keyboard to Russian one:
In my case it helped.
Nevetheless this effect is under investigation to be explained and corrected :).
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Hi Pawel,
Your trick is working
Roman Zhelezniak
Dear support team,
Could you provide a proper solution for this issue? "tricks" are not working in our case. Thank you.
It is not written in which version you observe these effects and the resolution of screen capture makes it difficult to read but I guess this time it is not related to any "tricks" but to standard behaviour of Robot in all versions up to 2013.
All these versions of Robot are non-Unicode so to correctly display non-Unicode caracters (including Cyrillic ones) it is necessary to select appropriate language in regional settings of Windows:
Note: after this change Windows is restarted.
BTW:
Starting from 2014 release RSA supports Unicode so none of above settings or "tricks" is necessary!
