I'm wondering when i design combined footing , i tried to adjust the columns dimension and the spacing between cols .. then the robot should calculate the dimension of footing & the soil pressure under footing accroding to the applied columns load .. the probem when i was try to adjust the columns dimension this message appears .. so how i can solve it ?
Solved by Artur.Kosakowski. Go to Solution.
Neglect it .. even if you correct it , the problem still appears .. i tried
Try to type A as 4m.
I tried .. it's not work ,, the problem still existing
Attach the rtd file ad indicate the name of the foundation to look at.
i'm not start to design .. because i can't modify the column dimension
this is the example
http://site.iugaza.edu.ps/sshihada/files/2012/09/Footings-3.pdf
Thanks a lot Arthur .. another question how i can get shear force & bending moment diagrames ?
The values of design forces can be found in the calculation note. The RC Spread Footing module doesn't create diagrams of bending moments or shear forces.
Okay thanks a lot .. the last question is Df say = 2 meters .. there's two choices N1 , Nf .. which one i can use to enter Df ?
'm not sure if I understand your question correctly. Could you attach the picture that illustrates the situation please?
hi
i have similier problem which is the dimension between column is less than the real one in the model
how can i fix it
in the plan is about 3m while in the design dimension is 0.75m
