Nothing happen when I want to go from CBS to the reinforcement modul into ROBOT 2014.
Usually, it is working but it seems to be a problem related to this file (it happened twice).
I also try to "Save as" but nothing happen as well.
Solved by Artur.Kosakowski. Go to Solution.
I can't attach the CBS file, le web site says :
"The file does not have a valid extension for an attachment. pdf,rtd,doc,pdf,dwf,dwg,dxf,dst,gz,gzip,zip,bm,bmp,gif,jfif,jpe,jpeg,jpg,psd,tif,tiff,png,xml,xls,lsp,svf,3ds,vcf,png,text,txt,log,env,dcl,rvt,rfa,ipt,iam,ipn,dwfx,idw,csv,nwf,nwc,nwd,sdf,cfz,vtfx,vtf,pat,f3d are the valid extensions."
For some reason the file has got save without results option set as default. Please follow the steps indicated on the attached pictures.
