in the name of GOD .
hello
I Design Steel Connections in Robot 2013 and when update model in Revit Structure 2013, Steel Connections isn't appear in Revit Structure 2013 model.
how can I Import Steel Connections from Robot 2013 to Revit Structure 2013 ?
You can only export these connections which are available for Revit Extensions.
the Structure has both these Connections and other Connections but isn't transfer any Connections.
it's very bad.
I want transfer my Structure from Robot to Revit Structure and then from Revit Structure to Tekla Structures.
because I want transfer Structure with steel connections from Robot to Tekla Structures.
What way is there to do this?
Such workflow is not directly supported by Autodesk. As it has been already explained both links (Robot to Tekla as well as Revit to Tekla) are owned by Tekla.
Hi all
I was see video on this link
in this video "Bidirectional link with Revit " then can update connection from robot to revit.
But I trying update result and model in robot to revit, and then not connection in revit
Pl guide me: how to update connection from robot to revit?
Thank all so much
