Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Problem in Export Steel Connections to Revit Structure
6 REPLIES 6
mpcloob
1899 Views, 6 Replies
in the name of  GOD .
hello
I Design Steel Connections in Robot 2013 and when update model in Revit Structure 2013, Steel Connections isn't appear in Revit Structure 2013 model. Smiley Sad
how can I Import Steel Connections from Robot 2013 to Revit Structure 2013 ?
6 REPLIES 6
Artur.Kosakowski
in reply to: mpcloob
You can only export these connections which are available for Revit Extensions.
Artur Kosakowski
mpcloob
in reply to: Artur.Kosakowski
the Structure has both these Connections and other Connections but isn't transfer any Connections.
it's very bad.Smiley Sad
I want transfer my Structure from Robot to Revit Structure and then from Revit Structure to Tekla Structures.
because I want transfer Structure with steel connections from Robot to Tekla Structures.
What way is there to do this?
Artur.Kosakowski
Such workflow is not directly supported by Autodesk. As it has been already explained both links (Robot to Tekla as well as Revit to Tekla) are owned by Tekla.
http://www.tekla.com/international/solutions/building-construction/Pages/export-revit-tekla-structur...
http://www.tekla.com/international/about-us/news/Pages/tekla-launches-enhanced-interface-with-Robot-...
Artur Kosakowski
duchoabn
Hi all
I was see video on this link
http://www.autodesk.com/products/autodesk-simulation-family/features/robot-structural-analysis/all/g...
in this video "Bidirectional link with Revit " then can update connection from robot to revit.
But I trying update result and model in robot to revit, and then not connection in revit
Pl guide me: how to update connection from robot to revit?
Thank all so much
phikweg
so there is just no way to export these other connections to revit? How can i generate drawings with these connections and their details?
phikweg
Is it possible in Revit 2016 and Robot 2016??? i get the same error when i try to send connections from Robot 2016 to Revit 2016!
