Discussion Groups
Robot Structural Analysis
chorch123
Print variables in connection schemes (Robot Structural Analysis)
102 Views, 6 Replies
09-18-2013 12:41 AM
I have two questions about the possibilities of editing the connection scheme in Robot Structural Analysis.
When you print the scheme, you can edit its header. By default I have Author, File and Project.
One question is: Is there any possibility of adding the "connection name" automatically? If you have two or more connection the only difference between them is the drawing, and sometimes it's quite difficult to know which is one.
Related to this, I have another question, is there possibility of adding the number and type of bolts in those schemes. The whole report is too large, so when calculating I print the scheme to send it to design department and I have to write manually the name of the connection (in order to know where to use it) and the size of bolts.
Thank you very much
Please use plain text.
Product Support
Artur.Kosakowski
Re: Print variables in connection schemes (Robot Structural Analysis)
09-18-2013 02:01 AM in reply to: chorch123
You may include the the information about bolts in the manually entered name of a connection as shown on the attached picture.
Artur Kosakowski
chorch123
09-18-2013 02:12 AM in reply to: Artur.Kosakowski
Yes, but how could I shown that description in "Scheme" label?, because in the "Results" one, you already have it.
Product Support
Artur.Kosakowski
09-18-2013 02:15 AM in reply to: chorch123
Could you attach the screen capture that illustrates what you want to achieve please?
Artur Kosakowski
chorch123
09-18-2013 02:33 AM in reply to: Artur.Kosakowski
Here I show just what I would like.
I have seen that in the header project file and name are included as variables: @PROJECT_FILE@ and @PROJECT_NAME@, so, is there a variable for "connection name"?
Regarding size of bolts, it could be enough if the measurement of hole diameter is shown, could it be edit?
Thank you
Product Support
Artur.Kosakowski
09-18-2013 02:58 AM in reply to: chorch123
Will that work for you?
Artur Kosakowski
chorch123
09-18-2013 03:18 AM in reply to: Artur.Kosakowski
That's perfect
Thank you very much
