Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Principal View lost
4 REPLIES 4
rioja
343 Views, 4 Replies
Principal View lost
Hi all
In this file I have lost my principal geometry view layout
The only posibility to handle the elementes is to have a View:1 / Sellect All and "Edit in new Window"
How to recover the principal View, it should be undeletable isn´t
Then I have do something wrong
Best Regards
Marcelo
(The attached file is without results) Due to restriccions, the file is too large to upload
4 REPLIES 4
rioja
in reply to: rioja
I have left only one beam, erased all in the RC module designed beams columns and foundations
the actual file size is 58Mb compressed 3.8Mb (the .rtd original file size is 228Mb)
Can you tell me how to reduce the file size in order to upload this file
se2p
in reply to: rioja
Save it with another name
rioja
in reply to: rioja
Thank you
I have already done twice changing the file name, saving without results, deleting the elements, leaving only one bar
saving again with another name
After selecting all, copy, paste on a new file it tooks only the bar elements but not the panels
Artur.Kosakowski
in reply to: rioja
Try to change the structure type to Solid (Geometry > Structure type) and then back to the one you work with.
Artur Kosakowski
