Hey,
I've changed my desktop settings preferences (DEEP BLUE set) and now I would like to have it back.
I've tried everything to get the default layout back (reinstall, open standard.prt file from other RSA2015, ...)
Do you have any idea how can I get it back, the DEEP BLUE set?
Thank you
Solved by Artur.Kosakowski. Go to Solution.
Try to either delete or rename CfgUsr folder (C:\Users\username\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis version number\CfgUsr)
