Pre-stress cables
5 REPLIES 5
aramalhinho
554 Views, 5 Replies
Pre-stress cables
I'm getting some intabilities in some nodes and I can't understand why.
And my model it's not converging also.
I tried with a simpler model with only one cable structure and worked fine, but when I introduce others (see attachement) it doesn't work.
Can anyone check the model for any mistake I've done.
Thanks.
Andre
5 REPLIES 5
Rafal.Gaweda
in reply to: aramalhinho
Apply RX support in nodes 105to114By3 107to116By3
Cables do not have any rotational dof so bars 55to67By4 58to70By4 can rotate aound their local X
Rafal Gaweda
aramalhinho
Hi Rafal,
Thank you for the reply.
That solved the instability issue but now I'm getting a warning regarding the 'matrix' and that 'the critical load may have been exceeded', and it's not converging again.
Any thoughts?
André
Rafal.Gaweda
Far too low critical coefficient if you run buckling for self weight only.
Rafal Gaweda
aramalhinho
in reply to: Rafal.Gaweda
Hi Rafal,
Buckling on the cables!? Strange...that means that I need to increase the section of the cables? or add more cables?
Is there any tutorial or example how to do a cable analysis? Or the way I've done is correct? problem being the buckling.
Thanks.
André
Rafal.Gaweda
No, buckling of WHOLE structure
Search forum, but more less you made model OK, but structure is unstable (I mean it buckles)
Rafal Gaweda
