I'm designing a steel roof structure using Robot 2012 x64 on Win7. When designing steel connections (column base) the program seems to confuse tensile and compressive forces. I've attatched screen captures from a test I've made. When calculating the connection with pure compression, the results are given for tensile capacity.
Am I missing something vital, or is there an error in Robot?
Thanks!
Bjørn G.
Norway
Solved by Artur.Kosakowski. Go to Solution.
Please download and install Service Pack 1+2 Hotfix
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17847332&linkID=13140816
