Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Message 1 of 8
HoshangMustafa
247 Views, 7 Replies
Polygonal section
Hi Rafal
Hi Artur
When defining section as polygonal (n=8),
Please find the attached file: Section definition
The section will be changed and the width of the support will be 8
Please find the attached file: Beam view
Is ARSA correct in exporting the model to design module in this case?
How can I solve this problem?
7 REPLIES 7
Message 2 of 8
I'm not sure if I understand you correctly. Do you want to design such section in the RC Beam Design module?
Artur Kosakowski
Message 3 of 8
Hi
I used this section for the columns. In the design module for the beam supported by such columns,I encountered this problem. That is, in design module for the beam supported by columns (columns having polygonal section), the support width is shown as the same data entered for number of edges of the polygon section (n=8)
Please find the attached file. (Support width)
Message 4 of 8
Hi rafal
Hi Artur
Please find the attached file. This will clarify what I mean.
http://we.tl/1ylsuhfypu
Message 5 of 8
Hi
Message 6 of 8
I see. Thank you for reporting this issue. We will investigate this situation. The proposed workaround for now is to replace the columns in a model with the circular ones.
Artur Kosakowski
Message 7 of 8
Hi
Message 8 of 8
Hi Artur
Thank you for your reply.
