first of all sorry for my english.
ok i am modeling a building with 50 stories each 10 stories are differents.
for preventing errors, each 10 stories i draw than i run calculation and see results (Only added selfweight)
ok for the first 6 basement look at the mass, compare it to the Floors F1 to F10 it is verry small
and the biggest problem that F10 to F 20 are equal to 0
please help!!
Solved by Rafal.Gaweda. Go to Solution.
hi,
i tried what you told me didn't work
and in fact the list of objects that i copied was already in the load tables list so the Sef weight is assigned to the whole structure 😕 there is another problem here !! please help !!!
the zipped file is 6,638 KB is too lare to upload here so this is the 4shared link http://www.4shared.com/zip/Ug_4Wf6tce/ROBOT.html?
thank you!
