I have actually two questions here.
1. Are there rail steel sections in Robot? (UIC; RE)
2. Is there a way to calculate plasticity of steel section by stages? To determine the force needed for every phase of plastification?
I attached the image of M/rotation diagram, which should be similar to the relation of compression axial force and plastification due to buckling.
Solved by Rafal.Gaweda. Go to Solution.
