Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Piles Reactions
5 REPLIES 5
rodainnajjar1229
799 Views, 5 Replies
Piles Reactions
dear sir
kindly find attached file.
we have model with seismic analysis + manual combinations with pile ( bar with elastic ground + spring )
but when i check force + reactions for piles i have problem
reaction + force =0 only with load without seismic
..see ( pic 1.2)
file
https://www.4shared.com/rar/fVJV6pu9ce/131203-Rbw4-With_pile-check_fo.html
regards
Tags (1)
5 REPLIES 5
I can't access the file. Try to save it under a new name with no results and zip it. It should be small enough to be attached directly to the post or upload it using another file hosting service.
Artur Kosakowski
Any chance to upload the file on another location (not www.4shared.com)?
Artur Kosakowski
Please check if the model you attached is the right one as I get instability type 2 and the obtained results are incorrect.
Artur Kosakowski
