Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
BertelliMarco1095
333 Views, 5 Replies
Parametric SFB
Dear all,
I tried to use the parametric definition of SFB composed by hea 200 + a baseplate of 400x15. The moment of inerzia is different from the value calculated with the custom defined section (and also autocad massprop). Have you any idea for this difference?
5 REPLIES 5
Could you attach the screen captures of the section and the compared values please?
Artur Kosakowski
if the diffrence is slight, make sure you have exactly the same drawing (i mean including espacially fillet radius); As it is located at the top and bottom of section, it plays more than one could think.
The moment of inerzia are: parametric 8622 cm4 custommade 6684 cm4 difference about 30%
Please use the user section rather the parametric one for time being. We will investigate the cause of the difference.
Artur Kosakowski
Please install SP3 for Robot 2014.
Artur Kosakowski
