Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Parameter is Incorrect
3 REPLIES 3
jonpople
420 Views, 3 Replies
I have a model that has been transferred to Robot from Revit, I have tried to define the load types and have noticed that it is using the wrong design code. However when I try to change the code in Job Preferences, Robot crashes and I have an error message displaying 'The parameter is incorrect'
What can I do to change the design code?
Jon
3 REPLIES 3
Artur.Kosakowski
in reply to: jonpople
Make a copy of the file and open it in the repair mode. Try to change the design code afterwards.
Artur Kosakowski
jonpople
in reply to: Artur.Kosakowski
I have opened a copy of the file in repair mode and have successfully changed the design code - thank you.
But what is reapir mode and what does it do?
Artur.Kosakowski
In principle it is a similar option as the recover command in AutoCAD. It audits the file and tries to correct the possible internal errors as well as compact the data.
Please check also http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Error-message-quot-Encountered-an-improper-a...
Artur Kosakowski
