Hi
It would be very helpfull to be able to get panel cuts in table and the ability to copy a panel cut. For instance if you have different models with the same geometry it would be fast if you where able to copy panel cuts into a model.
And also to see the results from more than 14 panel cuts at a time.
Also it would help a lot if you could get more than one result at a time. If you need to check both top and bottom envelope.
