Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Panel Maps after non-linear analysis
6 REPLIES 6
tony.ridley
256 Views, 6 Replies
Hi guys,
When I run a shell element with a non-linear analysis, the results map is just black.
It only goes black when the layer is on "middle".  I get a normal map when the layer is upper or lower.
Is this an error in the program, or am I doing something wrong?
Tony
6 REPLIES 6
Tony,
What kind of results you display (stresses)? Please check the values for the middle layer in the panel results table - are they 0s?
Artur Kosakowski
Artur,
No, it is black for stresses in middle layer only for non linear combinations.
For the simple cases it works fine.
Upper and lower stresses report correctly, just not middle.  But there IS stress in the middle layer.  So I'm not sure whats going on
Tony
Tony,
Please send us both the model and screen capture that shows what to look at (and how it looks on your machine). Thank you.
Artur Kosakowski
tony.ridley
in reply to: tony.ridley
file here:
tony.ridley
hmmm told you I was having a bad Robot day.  It seems when I run the file I sent to you, it works OK.  I only opened it in recovery to cut down the file size, but it seems to have fixed the problem too.
Sorry for posting without trying this first.  Smiley Embarassed
Tony
Good to know it works (I was about to send you a nice picture with lot of colors) Smiley Happy
Artur Kosakowski
