Hi
I have a few questions on panel cuts.
1. Is there a possibility to get more results from panel cuts? At the moment, I can only obtain minimum and maximum values, but I'm also interested in some intermediate values. See attached sketch.
2. Is there a possibility to easily convert those results to an excel format, so I can reproduce the graph in Excel?
3. Also, very often, when more than 1 panel cut has been made, the results are not updated anymore (i.e. changing MXX to MYY to NX doesn't produce different graphs / indicated values). This is even the case when only one of the panel cuts is ticked. Is there another method to make the panel cuts refresh - apart from deleting all others?
Thanks in advance.
Best regards
Edit: I'm using Robot Structural Analysis Professional 2011.
I am afraid not
Strange?!
Update your robot with all available service packs, update your graphics card driver...
Try 2013 version even in trial mode.
You need to select (highlight on the list) the cuts you want to change the display of results for first and then change e.g. MXX to MYY. The tick only indicates the cut you want to show the results for (visible / not visible).
Hi Rafal,
Is there any chance to export map results (from panel cut) using the API?
Hi Rafal,
