It will be very powerfull if you can add an option in the panels or claddings definition that allow you to create a node-dependent panel or cladding.
In this way if you need to modify the structure geometry by node coordinate, you can transfer this modification automatically in the panels or in the claddings, avoiding geometry imprecision in model definition.
It will be very powerfull in large models or in complex geometry model.
