My model is a vertical tubular structure (underwater) under sea current conditions.
(weight neglected)
I want to calculate the large displacement going on.
I use P-Delta non-linear analysis.
My current model does converge in the linear mode with strange displacement results (8 km displacement) but does not converge in P-delta mode.
I suppose P-delta to be more apropriate for large displacement. I do not know if this calculation is feasible or my model is wrong in some way.
Solved by Rafal.Gaweda. Go to Solution.
Precisely.
I precise, it is the height of the system I want to simulate.
A vertical tubular profile, very deep in the water.
It is cable like behavior.
Correct settings: generate 20 nodes on each long bar, set Netwon Raphson - see below
I do not know if you made model correctly - please check FZ reactions.
I am doing it wrong: still no converging.
If I am correct:
-> dividing the bar provide freedom and make the "cable like" behavior possible.
-> increase the load increment because we are in presence of very strong loads
-> I do not understand what is BFGS
-> Matrix update each iteration in order to set Netwon Raphson
