Solved by Artur.Kosakowski. Go to Solution.
By default any contour defined 'inside' the larger one is recognized as an opening. You can see that after selecting its contour and pressing the right mouse button to access Object Properties. In case it is set as e.g. a panel you can modify it to be the opening as shown on the attached picture. To make sure this object is correctly recognized select the 'outer' panel and run local meshing for it. The mesh should be generated in such a way that there is no surface elements inside the opening. In case you still have problems with the definition of the opening reduce the model to the 'outer' panel and the contour of the opening and upload it so that I could have a look please.
Replying press the Browse button and select the file you want to attach.
Please delete the mechanical part that is visible on the left hand side of the picture leaving only the vertical panel and the rectangle that stands for the contour of the opening you want to create. Save the file under a new name and attach it.
I'm sorry for not writting that clearly. I need the rtd file rather than a picture so that I could access the properties of the objects you created :-). Just send me the rtd file you make the last screen capture from. Thank you.
Could you try to compress it (*.zip) or just rename it to *.jpg and I'll change the extension back to rtd. Please check what file types you have got set in the displayed attachment dialog and make sure it is All files (*.*).
Apparently you have marked 'define as default in a solid modeler (acis) format' in Robot's Preferences on. This results in generation of acis type objects rather than 'standard' panels and is generally recommended for some type of solid (volumetric) models only. Please switch it off for shell type models.
As you defined your panel as the acis object you have to use Bollean operation to subtract the opening as shown on the attached picture.
Sorry, you may want to try this .zip file. It contains the correct .rtb file
I managed to rename the previous file. I think the solution I proposed is still valid
Sorry about the previous post. It was ment to read: Thank you very much, your solution warked perfectly!!!
In such case can this post be marked as solved? Thank you for confirmation.
