Hello!
I have just installed Robot Professional 2011. When modeling a "Building Design", the only possibility is to introduce the columns "down z"...the option Up Z is blocked. Can i do anything to change this ?
Thx in advance!
Solved by Jakub.Brozonowicz. Go to Solution.
To make it active just go to object inspector and with RMB on Stories switch Filter structure stories off.
Check the picture attached, please.
