Please could somebody explain how to successfully combine the two pipes (combine panels 14,15,16, 19 with panel đ in the attached model? Have tried various object combination methods (including the examples on previous posts in the forum) but nothing seems to work for me.
Thanks in advance..
Solved by Rafal.Gaweda. Go to Solution.
I guess objects 14to16 19 should be made as a one "cone".
1. Cone tube as a Cone
2. Bottom shaft cylinder as cylinder with 128 circle divisions
Check attached file, check thicknesses, remove temporary bars
Hi Rafal.
Thanks for your help. I think I understand now. Will just have to change it slightly as the walls of the vertical cylinder should be sloped, so I assume that modelling this as a cone (similar method to the inlet pipe) should be ok...
Thanks again.
