Hi
I have a model, in which I have changed the code combination regulations and member regulations quite a few times, and generated Combinaitons. Its working fine.
But when I changed them back and when I click generate in Automatic Combinations, nothing is happening.
I have found a Thread with the same problem (below is the link), I have tried the selected solution, but it is not working.
Solved by Rafal.Gaweda. Go to Solution.
Hi Rafal,
I have attached the file.
I have sent the password for the zip file as private message to you.
I do not see any problem.
Keep in mind that automatic code combinations are generated automaticaly AFTER finishing FEM calculations, not just after pressing Generate in Code Combination window.
Thank you Rafal
I always check the combinations after clicking the Generate button. Thats my mistake I guess.
rafal, why is that the generated automatic combinations does not include earthquake load definition when the calculation is runned but only dead,live and wind.
It depens on code used (if it includes seismic cases \ combinations).
See example below:
thank you, that suggest that if it doesnt support, then i need to enter it as a manual combination.correct?
