Hello, I enclose a note of calculation of a beam wall. Because the values of M and N are equal to 0?
Also trying to export the armature in Detailing, an error message appears 'problem of run'. Why is that?
Solved by Artur.Kosakowski. Go to Solution.
Solved by Rafal.Gaweda. Go to Solution.
It must be analyzed by developers.
Not possible to export wall (in general panel) drawings to ASD
Send me your rtd file and indicate which panel to focus on please. Thank you.
The file is very large. I'm enclosing the link to download it:
http://wtrns.fr/N4A-oj1f2XEMRVJ
The panels are those already present in the verifier of the reinforced concrete.
thanks
You need to import panels from the model and calculate provided reinforcement again in v.2013SP1.
