Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Normalized axial load ratio for Columns in EC8
2 REPLIES 2
patkson
1415 Views, 2 Replies
Hi all,
I think I would commend RSA team for improving on the column design by including the computation of the normalized axial laod which is
to me a very important factor under seismic loading.
However I have a little bit of misunderstanding that I would like to seek some clarification. In computing this, robot uses material factor of 1.2 for concrete thus fcd =fck/1.2
However  EC8 5.4.2 (2p) " seem to indicate otherwise. Infact this justifiation seem to suggest a factor of 1.5 for transient and persistent be adopted for ULS verifaction which makes the fcd=fck/1.5.
I will like to seek some insight on that.
Thank you all.
Regards
POk.
2 REPLIES 2
Artur.Kosakowski
in reply to: patkson
Robot follows the general rules of the code which defines yc as 1.2 for accidental ULS (Robot classifies seismic action as accidental) but you can change this factor manually in the way shown on the attached picture.
Artur Kosakowski
As I understand,we limit the normalized axial force in column (0.65 in DCM and 0.55 in DCH) or wall (0.4 in DCM and 0.3 in DCH) to avoid the "brittle failure" and the choosen section is reasonable in thsi range.
Is there any other different meaning for normalized axial force ? Why do we need to limit it ?
