From "Non-linear Static Analysis - Parameters" section in the help:
Matrix K actualized after each iteration - Off.
Raphson method: Matrix K actualized after each iteration - On.
1. Off/On settings above are the same for both Modified Newton method and Full Newton method.
2. The default Robot setting is On & Off, which method does it trigger?
3. What happens when both options are set to On & On?
Solved by Romanich. Go to Solution.
Hi Patrick,
this is error in Help.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
Patrick
The help file is also incorrect (as pointed out by Romanich);
see
Tony
Fixed in the online help.
See:
http://help.autodesk.com/view/RSAPRO/2015/ENU/?guid=GUID-FB3C86D3-0E30-43A6-82D6-6C50F429FA0D
If this post answers your question please click the "Accept as Solution" button. It will help everyone to find answer more quickly!
