Discussion Groups
Robot Structural Analysis
Distinguished Contributor
PatrickEC
Non-linear Static Analysis - Parameters
649 Views, 2 Replies
09-05-2012 04:03 PM
From "Non-linear Static Analysis - Parameters" section in the help:
  • For the Initial stress method - Matrix K actualized after each subdivision - Off.
    Matrix K actualized after each iteration - Off.
  • For the Modified Newton - Matrix K actualized after each subdivision - Off.
    Raphson method: Matrix K actualized after each iteration - On.
  • For Full Newton - Matrix K actualized after each subdivision - Off.
1. Off/On settings above are the same for both Modified Newton method and Full Newton method.
2. The default Robot setting is On & Off, which method does it trigger?
3. What happens when both options are set to On & On?
Please use plain text.
*Expert Elite* | International Moderator
Romanich
Re: Non-linear Static Analysis - Parameters
09-05-2012 10:30 PM in reply to: PatrickEC
Hi Patrick,
this is error in Help.
Valued Mentor
tony.ridley
09-06-2012 05:43 AM in reply to: Romanich
Patrick
The help file is also incorrect (as pointed out by Romanich);
see
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Help-file-error/m-p/3368727/highlight/true#M...
Tony
