• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • 13 Kudos
    Node selection
    Status: New Idea
    by Valued Contributor Tuctas ‎02-16-2013 10:51 AM - edited ‎02-16-2013 10:53 AM
      When we select a node by indicating its number, it is marked with a green color spot in the structure but if the structure is a little more than simlpe it's difficult for the user to see where it is... It should be marked by a different (more clear) way, for instance the node could be enclosed in a small circle in order to be visible.
    Comments
    by Valued Contributor Rafacascudo on ‎04-26-2013 10:01 AM
    on display options , mark " display atributes only for seleceted elements " and then click to show node number.you will easily find it
    by Valued Contributor Tuctas on ‎04-28-2013 10:54 AM
      I didn't notice any big difference in the visibility by choosing this option..
