Discussion Groups
Robot Structural Analysis
Valued Mentor
Accepted Solution
Node Number
231 Views, 2 Replies
01-26-2013 12:42 AM
Hi
When I hover over a node the node number doesn't display. What should I do?
Please use plain text.
Product Support
Artur.Kosakowski
Re: Node Number
01-27-2013 11:24 PM in reply to: HoshangMustafa
It should also be visible at the bottom of the screen
Try to save the project, restart Robot and open the saved file again.
Artur Kosakowski
Valued Mentor
Re: Tie beam on ground
01-28-2013 02:49 AM in reply to: HoshangMustafa
Hi
I Found it in the Display-Nodes-Hide Nodes
It was checked
Thanx
