What is the correct way to apply soil pressure ( reaction ) for raft foundation ?! when i apply Kz (Subgrade reaction i calculate it from 120*qall ) but the problem is when i analyze the raft appreas problem ( No support ) ?! how is that ? .. and how i can show the pressure under footing ??
Thanks in Advance
Really i'm confusion .. that's links scattering me rather than help me
Okay i did it .. and the soil map aprears .. but when there's problem ( no support ) . i don't understand , correct me if i'm wrong , this soil reaction Kz works as support , so why there's no support ?
Why no support ? that's my question .. i definedKz correctly
Have you applied any of nodal support? linear support? planar support ?
-> the answer is NO, you have used KZ in panel thickness defintion.
KZ defined there is not a support (understood as robot object \ item) -> warning saying "No support" is correct = no such object in your model used.
