Following on from an earlier issue, I have corrected and now come across the error message in the analysis in any load combinations which I have simple load case 'temperature rise' applied.
I already have a similar simple load case 'temperature fall' which doesn't give the same problem. I have already went through and deleted/reapplied loads and combinations for the specific simple load case 'temperature rise' but to no avail.
All parameters are set as http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Nonlinear-analysis-Iteration/m-p/3385747#M35...
Try the setings below.
It may happen that some simple cases may not converge due to lack of selfweight or...
IN such case set such case as Auxiliary then use it in combination(s).
If you want deeper check please send us model.
Unfortunately it happens for all load cases in which the simple case is applied. 'Temperature Rise' Load case
Would it have anything to do with truss type bars acting in Tension/Compression only and/or with pinned ends?
Edit:
I answered my own question. When I remove all my flat bars acting in tension only I get the error message.
Now the question is how do I model Flat bars in tension only? I don't think modelling them as cables is the correct way to go, as it doesn't take into account the Flat bar member section properties?
Yes that's right, you can't add temperature effects to bars with advanced properties of tension / compression only.
Normally I'd just avoid adding the temperature to these bracings. they have small cross section so the effects are normally not that great. You could work out the tension imposed on a bar by the temperature and then just apply an axial force to the bar to represent that temperature.
Tony
As Tony said or set this case as AUX and use it in combinations...
For any deeper check we need the file
