in my model sometimes it's impossible to change the height of some walls. According to the dialog inspector box those walls are defined by an area and 2 points, but when I click on the contour definition button to change their geometry, in the new window their height is wrong and the fields with beginning and end are empty.
Thanks.
Solved by Rafal.Gaweda. Go to Solution.
Check this: http://forums.autodesk.com/t5/Robot-Structural-Analysis/Incoherent-mesh-problem/m-p/4963896#M22794
And you can use these macros if you need:
Thank you very much.
If I leave the walls as they are, when I mesh the model I get 2 warnings on those walls "Cohesion of the calculation model has been provided by definition of the kinematic constraints in incoherent points of the finite elements mesh" and "Incoherent mesh on edges". Since they are just warnings and not errors, should I correct the model anyway (passing through the definition of a panel element) or I can leave the walls as they are.
