Dear Support,
I received a project from customer with all the beams and columns already named and I would like to use the same names in Robot.
When I export from Revit Structure to Robot, Robot recognizes the name (see an example in the attached file, it imported the right name: B-2.25), but when I do the calculations and the drawings, the name that appears in the sheet is the internal Robot's number. In this example: beam 79.
In other words, is it possible to have the imported name on the final drawings automatically?
Gustavo
Solved by Rafal.Gaweda. Go to Solution.
Thank you. I was looking for something easier, I mean automatically ... but thank you anyway.
